Need help on old xzillarator harness model DXZ01s how map sensors get wired
I have an xzillarator model DXZ01s that has had the map sensors cut off and im trying to figure out how to wire the new plugs i ordered for it. The harness has 2 wires coming out of it and im trying to find out how to wire the male and female map sensor plug. I bought an ls tps extension plug and it has the male and female plugs that i need wired to each other so ill cut that in half and have three wires coming out of each plug i know one wire is a jumper but i need to figure out which one will be the jumper and then what to do with the rest of the 4 wires
