Quadzilla XZT+ smoke switch
Well that kind of tough... There is 3 wires to the MAP sensor... 1. +5 Volt Supply2. Signal3. GroundOn Edge comp you want to turn off the signal line or disconnect it.On most others you want the +5V connect to the Signal lead.Now the problem is that the wire color and pin assignment changed from year to year. Even the plugs changed. So it will be up to you to test for the 5V lead and the signal lead. The signal lead will be the only one that won't change when the key is turned on! Also the stock wiring to the ECM should not be altered... Only the wiring to the quadzilla...
