Question on hot hard start fuel pump kill relay.
Thanks for the diagram on the lift pump kill relay for the hot hard start Michael! That's just what I was looking for! I'm assuming you're just using a normal, 12 volt relay? -Pin 85 on the relay you're just tapping into the starter solenoid wire?-Pin 86 on the relay is just to ground?-Pin 30 on the relay is the positive wire that would be going into the stock plug on the stock lift pump if I was using the stock pump?
  • Views 1.7k
No posts to show
