No cruise control with new clock spring installed
Hello all, I replaced the clock spring yesterday. And no cruise control with new one installed. On the old clock spring I would get it once in a while. But after install I took for a spin and nothing. No light in dash. Do I need to go in with my Snap On Modus and clear any codes due to disconnecting the air bag? Is didn't find any fuse. Or maybe I over looked it. Any help will be greatly appreciated.Thanks,John
  • Replies 3
  • Views 2.5k
No, They never did work thats why I changed the clock spring. I must of had the wheel in a certain position intermittently and the cruised worked when the old clock spring was in. I replaced with new one and nothing worked. I went back and checked all of the connections. And another thing to mention I need new back brakes could that be a cause? Also when driving I tried pulling up on the brake pedal and nothing there either. Do I need to rest any codes in the computer? I have a Snap On Modis I can use. If not what else can I look for? Any help would be appreciated.Thanks,John
