Posted (edited)
Well gang I got a shot at doing starter contacts on a 5.9L Dodge Gasser Ram. As a matter of fact it rather easy to do just like the Cummins version but just smaller starter. The contacts were provided by my local NAPA store which I come to find out they ordered them from LarryB's http://startercontacts.com/ But it just remove the starter from the truck as usual and remove the 3 small screw on the solenoid cover. Now remove the spring loaded plinger contact and spring. Now that you remove that you can see the other 2 contact which are just bolted to the case. As you can see it just a matter of removing a few nuts and slipping the old contact out and slipping the new contact into place and reassembling the starter.
