Non Gated HX35.
I was just curious if anyone is running a non gated turbo? Does not have to be an HX35, I just happen to have a non gated with a 14cm exhaust housing. I cant decide if I want to swap the 14cm onto my gated or just throw on the non gated turbo and give it a whirl. I know running a non gated housing requires more attention to the boost gauge and skinny pedal control. I however do not have much done to my truck and doubt it would get to its upper limit anyway. As usual, thanks to all for reading and replying.
  • Replies 3
  • Views 2.2k
No problems except you have no drive pressure release. Just dont go over 35psi. Aurora 3000 which is quite popular are non gated I believe (for example)
Thanks John. I think I will just swap out the 14cm housing onto the current charger I have. It has less play than the non gated charger x2 in the garage. I suppose I will sell the two non gated 12 cm's here soon.
Try it but dont think you will find much EGT reduction. People talk about it ..... but I think it has more to do with the exhuast side turbine rather than the AR of the housing. I prefer smaller AR housings for spoolup
