Starting the rear end over haul
Will update with pic and a little right up.Plan on doing it in this order1. Paint the frame/axle and all other related parts 2. Install the draw straw and 1/2 hose with jic/an fittings for airdog150. Airdog is already installed will post a couple pics.3. Install the locker with new hub seals,pinion seals,pinion nut and mag- hytec cover4. reinstall the axle and re paint frame and axle with 2nd coat of paint.5. new bilstien 5100 shock and put the bed back on.
