alternator question
Will a denso alternator fit if my original is a bosch, i.e. are the connectors and mounts the same? I was trying to replace the brushes today with Gould's brush/bearing kit, and the rotor seized on my somehow, and now need new alternator. Thanks.
  • Replies 2
  • Views 1.3k
The mounting of either to the engine will work. The electrical hook-up is in a different orientation but so long as your wires are long enough there should not be a problem.
Thanks. I picked one up at Napa last night and will stick her on there this morning.
