November 9, 201313 yr The stats: [*]1997 Dodge Ram 2500 SLT Ext. cab [*]260K+ miles [*]5.9L Cummins 12valve turbo diesel [*]4x4 [*]NV4500 5 speed transmission [*]KY clutch 3850# dual disk ceramic clutch [*]1 3/8" cryogenically treated input shaft [*]3.54 axle ratio with LSD in the rear [*]265/75/R16 Cooper Discoverer A/T3 tires [*]Custom cut fuel plate [*]AFC full forward [*]3k governor spring kit [*]Timing set at 15.5 degrees [*]Diamond eye 4" turbo back exhaust with 5" tip [*]Glowshift 3-in-1 Boost, pyrometer, fuel pressure [*]Boost elbow [*]Amsoil EAAU4095 air filter with prefilter [*]Mighty diesel head bolts [*]Power at the wheels is sitting around 360HP and 800FT.LB. of torque right now. [*]All maintenance, repairs and modifications done by myself. Picture from after I brought the truck home back in fall 2012, will add more recent pictures later.
The stats:
[*]260K+ miles
[*]4x4
[*]AFC full forward
[*]Boost elbow
