got question
Guest
does anybody know were you can get a better deal on 4inch stacks for a dodge diesel ? if you know please let me know thanks taz :burnout :thumbsup :coal :?:
If you want to build a stack, galv 90 deg 4 in elbows are just under $40 the each.Losses in a tee are nearly the same as the elbows so a pair is a looks thing.If you elbow up with galv pipe you may be under $100, including the black paint.Truck-Pro has the parts for heavy trucks.keydl
  • 10 months later...
So there is more to be had by these trucks... My 92 Dodge we turned up the fuel screw till we couldn't adjust the idle down anymore... Assuming that was it...So how do you re-index the throttle? (Pics Requested!)
