Just installed the Rock Solid bushing today and wanted to share my thoughts. After repairing my seized steering shaft I went through the directions and started the install. Instructions were detailed and helpful. I performed the install on the truck and found it easier to remove left front tire and fender skirt. After that it was pretty straightforward. I did make a longer installer out of pvc pipe so that I could drive it in from the fender well. The results are very good. No more rattling column and steering is tight. All in all it was a good investment of time and money.
  • Replies 3
  • Views 2.3k
I just order it tonight and also the steering box brace I'm hopping to do it in a afternoon i glad to see it kills of the issue my truck is grinding.
I think you'll be happy with it. I'm going to get the steering box brace soon too. Let me know how everything turns out.
