Heated power seats, plug and play?
I have been wanting a heated seat for some time, especially after driving a jetta with heated seats.
Anyway long story short is a got the whole front and rear leather seats.
Power and heat on both sides. have the switches that go in the dash.
Also got the storage tray under the back seat and the woodgrain dash.
I guess my question is...how much grief is it to get the heat to work.
My drivers seat is power and that was plug and play.
This is probably going to mean I need a wire harness...ugh.
Regards Chris
Well so far I have puled the bottom cushions off and looked over the wiring.
Same plug as my truck has, so all the power adjustment motors should work fine.
Everything goes in the 1 single plug and then there are extra plugs going after that to run the heaters.
Hopefully and I mean hopefully the plugs are in the dash for the switches.
If not then things get nasty real fast.
Regards Chris
