Custom Quad Headlights w/ HID Bi-xenon Projectors
In the end, cheap imitations will always be cheap imitations.OEM projectors are of course superior in beam pattern and light quality.But mounting them in a housing they were not designed for is a real nightmare.The projector is only part of the complete lighting system, and crispness and clarity dont have to be 100% dead nuts perfect in order to satisfy your needs.Anyway around it you are hanging an object that weighs nearly a pound off a structure that was designed to hold an ounce. And the weight is further out too, by a long shot! :cookoo:
Sorry to hear about your troubles man! Those headlights look pretty sweet though! Which I had the patience for something like that. :thumb1:
sometimes I wish I did too, lol. I use up most of my patience at work then i get home look at the headlights and the clock........ i'm still fidling with the design a bit too the adjustment screws for the projectors i wound up changing a couple times, the initial thought of bolting both projectors together first actually has caused more problems then it solved so i am working out bolting them separately with the ability to adjust the left right up down and rotational of each projector. I don't know if I will keep it that way for the final design or not but it should help atleast in the prototyping faze.
