  • Entries
    19
  • Comments
    5
  • Views
    30,378
About this blog
Thor
2006 Dodge Ram 3500, 5.9L Cummins, 6 speed G56, 4WD, +50HP Injectors, AirDog 150, BHAF
Entries in this blog
With how the wintertime is going for us up here. I pulled Thor back online to see if I can get more done. @Tweety Bird and I ran Thor to Lewiston, Idaho, for our shopping trip for chow and supplies. Thor is actually running quite well when fully warmed up. Even with a weak set of rings yet, Thor fires up every cold morning with white smoke and offbeat idle till those rings warm up some. Thor has been a comfortable truck to run, but there is add ons I'm looking at doing. First, I'm going to look
Today I'm going to get myself together and get out and do the battery terminals on Thor. Yeah, it's a cold start here this morning. It's going to be a warmer day heading into the mid 50's at least. I want to get the new battery terminal and copper lugs installed today. I figured I would check over the website. @yohon and his rebuild, and helping out where I can. Every day can be a battle for me. I love what I can do, but my body tells me all about it when I try too hard. This is the depressing p
I've been playing with Thor to see if I could fix the AirDog 150 to get closer to 15 PSI. I found a spring at my local hardware store, and it was way thicker, but after a bit of trimming work, I got the fuel pressure to settle at 22 to 25 PSI. Yeah, I know it's high, but I wanted to be sure the CP3 is loading fully and getting good, solid rail pressure. I'm struggling to understand the grid heater light, and it typically trips on deceleration. I'm doing more testing to figure out my issues. Toda
With Beast leaking oil out front and rear main seals, needing tires, and closing in on 500k miles. Beast needs work to keep him going. Mark suggested to try looking into Thor. Luckily my fuel pressure test gauge made it and was intact and undamaged. I checked the fuel pressure key on, engine off, barely 7 to 8 PSI of fuel pressure. Now start the engine, the fuel pressure drops to 2-3 PSI with WOT stab of the throttle. Ugh! Now I pulled the check ball and spring and did my typical spring mod bend
Got up today and hopped out after Thor to finish up the front seats. The driver's side repaired seat looks patched and actually appears correct in the roll of the foam. Being I've got 3 days plus of clear warm weather coming we need to get @Tweety Bird moved out of Nampa ID, promptly. The Big Tex trailer is all hitched up and tested, all tail light functions are present and even for short trip down the driveway and back up the side yard I had good brakes on the trailer and you can feel it tug ba
I was coming back from Lewiston, ID, a few days ago. I looked down at my fuel gauge in Riggins, ID and just above 3/4 of a tank. Within about 2 miles, it popped the elbow quick connect off the return line and started pumping fuel on the highway. I notice the fuel gauge rapidly dropping shut the key down. The AirDog pump stopped and pulled over, found the quick connect fitting blew off, and dumped $100 of fuel on the highway in under 2 miles. I'm in the process of hunting down the old steel JIC c
Today I bounced outside, and it was warm and sunny. I wanted to get busy trying to make Thor cleaner and comfortable. Yeah, grab the power washer and nearly a gallon of degreaser and give Thor a good washing down on the engine so I can hunt oil leaks and other things. Don't need a greasy engine. I sprayed down the door jams and hinges so I can lube them back up and get the creaky door hinges to stop. The driver seat was pretty bad I peeled the seat bases out of both sides. Not really hard, just
@Tweety Bird and I loaded up into Thor. I've got a medical visit here in Nampa to see about saving my right kidney. Thor is going be helping us relocate tweety bird to my nest. Yup, she is moving out and in with me. As for the trip down Thor ran great. Very smooth ride and good power till you build a little bit too much boost... P0234 code. Funny. Pull over erase the error code and continued down the road. Now comparing the previous MPG to now. 4 MPG gain. Still remember I've got blow by issues
Yeah, Thor is in rough shape. The interior is well-worn and dirty from two years of my using it as a service truck. Now, Thor is becoming the next article truck for the website. I've got a Mopar1973Man banner already pulled out for the truck's rear window. Then, Thor's first task is going to be hauling a full load of scrap metal to Lewiston, Idaho. Thor is going to provide all the 3rd Generation articles we need. I'm currently writing an article for the AirDog 150 fuel system I'm installing. I'm
Thor is on the road. OMG! What a change to dropping that flatbed and going to a normal truck bed. I've got scale weights from back when Thor was a service truck and now with the normal truck bed. Flatbed with tools and all equipment - 9,600 pounds Normal truck bed -------------------------- 7,300 pounds Weight Savings ---------------------------- 2,300 pounds This truck is quick now. I can row the gears and accelerate pretty darn quickly. Thor still has a few issues, like the exhaust brake
Here you go, gang, I've gone and done it now. I found the next great hiding place on a 3rd Gen Truck and gave the AirDog a protected spot. I mocked up the bracket in the bed and then mounted the pump bracket upside down against the inner bed wall. This makes it a bit tricky to get the 4 Allen bolts in and tight. Then I managed to get the suction line hooked up to the modified sender straw. Then I removed and cut the filler neck hose and inserted the return tee into the filler neck hose. Clamped
I got a little bit done today with Thor. I've now got bumpers on Thor. The rear bumper is off a 2005 Dodge Hemi and fits perfect. I got it bolted up and license plate on the rear bumper. Looks good. Now the front bumper is off a 4th Gen truck doesn't quite fit right. Its a bumper and will have to do for the time being. Now the other problem is the electrical is strange but 2006 was a single year where the taillights was totally different. It's like the 2007 for all the plugs and everything works
I had to make a return trip and try to find the right wiring for a 2006 Dodge Ram. The weird part is that a 2005 tail light loom has different plugs than the 2006 main plug. The 2007 loom is totally different and is missing the white/tan lead for brake light, assuming that there is a turn signal stalk that cancels and supplies the brake signal down the turn signal lead like typical. Nope, Thor is different, where he has a separate tail light bulb for a brake light. Being I cannot get a 2006 loom
I spent some time this morning tracing out the brake light function from the cab to the taillights. Then I found out the taillight loom I got from a 2007 will NOT work. It's a single taillight setup. Problem I figured out that there are two taillights in the wiring diagram and then started looking for the white/tan lead nope. Not there. Now I'm on hold, waiting to see if the salvage yard has a 2005 wiring loom so I can get the right wiring. The project is on hold for a bit to sort out the elect
I had other running around to do today. By the time I came back home, I only had a few hours of daylight left before the shadows of the mountain start casting on the valley floor. I managed to get the filler neck installed and managed to cut the unleaded neck out to fit the diesel fuel nozzle at a fuel station. I was getting sore from lying on the ground to deal with that, so I shifted over to dealing with the brake light issue. Now I got power past the brake light switch still not making it to
I managed to get alot done today on Thor. Everyone was pitching in between Mark and Suzanna. We temporarily rigged up the AirDog fuel system so I could move the entire truck outside. I've got a trick I'm going to show on Thor that I'm doing for a AirDog soon. Already got the straw done in the sender basket. Then pulled Beast up with the trailer and used the a-frame to unload the new bed for Thor. Then, Thor was fired up, rolled out the door, lifted the bed up, and carefully lowered the bed back
Yesterday, I got the electrical for the bed strung down frame. I have all new electrical running to the bedand taillights. Now I've got to get Mark to give me a hand and unload the new bed from the trailer to the frame of Thor. I'm planning on installing the AirDog 150 too. Today I've got to grab my old fuel pump I saved on the shelf and drill the straw through it and install. I've got a awesome idea of installing the AirDog in the bed side but I gotta look ar how much room I have after the fill
A lot of things happened today. Actually, back up to last night, and I was making calls on getting a hold of a trailer to haul back Thor's new bed. Found a local friend I could borrow his trailer to bring the bed home. Yeah I have to use Beast one last time. Beast is leaking at both ends of the crank front and rear seals. I managed to get oil and an oil filter for Thor. Then, fresh coolant. I'm hoping to do a recrimp of the radiator here very soon. Back on track, I've got to haul down to Horsesh
Yup. Thor is a running and driving truck now. I've been fighting to find a 3rd Generation bed, taillights and tailgate for Thor. Surprise, Surprise! The 3rd Generation trucks in the Boise Valley are all short bed. OMG! This is nuts. I spent over 5 miles of hiking just walking around the wrecking yards attempting to find a truck bed for Thor. Long Bed boxes are rare, and if you find one, typically the bed is completely hammered like I've got a few photos of trucks with long boxes but the truck lo
