How to Replace a Power Steering Gear Box
OK first, when removing the pitman arm, don't worry about marking it so you can put it on the same way. It's splined and can only go on 4 ways.
Power_Steering_002.jpg.ca1ff59a615f0a134
Power_Steering_003.jpg.85cfee084012fe90f
First step, remove the pitman arm nut, it's a 32mm if I remember correctly. Then install your puller, make sure to grease it up plenty. I made my own but I'm pretty sure Harbor Freight has one for a decent price. Just make sure to use it within 89 days of buying it!
Power_Steering_024.jpg.5d4a0df1f3bc8358b
After soaking it for a week in PB blaster, giving it a fresh shot every day. And then fighting that thing for a few hours putting over 2500lb's of pressure trying to get it off, I found a simple trick. I removed the 4 15mm bolts holding the sway bar in place, torqued the puller to 135lb's, and gave it 3 good whacks in this spot with a BFH. Then it came right off. Just be careful not to hit the box, so maybe a BFH's little cousin would be a better choice.
Power_Steering_025.jpg.38af13eaef38abbcd
Then to remove the steering shaft. If you turn the steering wheel so the top is facing the passengers door, the bolt (13mm) should be fairly easy to get to.
Power_Steering_016.jpg.7b3b1cd7c9798bee2
After you get that, remove the power steering fluid lines from the box, they are 18mm, If you're anything like me and wait for the box to blow up and loose all it's oil, then you don't have to worry about any oil wanting to leak out! otherwise, just put an oil pan under it and open both lines up and let it drain. I was able to go from the bottom and get the lines off fairly easily. But I've heard of some waiting to take them off til after the mounting bolts, and then just use a jack stand to suport the box until you get them off.
Power_Steering_011.jpg.2c3a63b3fc0f7ae69
Then for the 3 mounting bolts, super simple, don't know what metric size they are, but a 13/16" is nice and snug so I just used it.
Power_Steering_008.jpg.9703a64be6fca7f63
To ensure no mistakes were made, this was all done under the supervision of a highly trained professional!
Power_Steering_019.jpg.ed596e1f307f91fd1
Also, if you're like me and don't jack up the front end, when you reinstall the box, hook everything up, except the pitman arm, fill it with oil and turn it from lock to lock, top off the oil, lock to lock, top off the oil, lock to lock, and then hook it up, that way you don't have to drag the tires across the ground with manual steering to fill the new box with oil. But I would still take it for a short drive and top it off again once it cools down.
If you have any further questions, please feel welcome to ask them on the Mopar1973Man Forum.
User Feedback
More options...
Very good article. Matched up to my 02 perfectly. Much simpler than I thought.
