Welcome To Mopar1973Man.Com LLC
We are privately owned, with access to a professional Diesel Mechanic, who can provide additional support for Dodge Ram Cummins Diesel vehicles. Many detailed information is FREE and available to read. However, in order to interact directly with our Diesel Mechanic, Michael, by phone, via zoom, or as the web-based option, Subscription Plans are offered that will enable these and other features.  Go to the Subscription Page and Select a desired plan. At any time you wish to cancel the Subscription, click Subscription Page, select the 'Cancel' button, and it will be canceled. For your convenience, all subscriptions are on auto-renewal.
DTC 62 - PCM Failure SRI Miles Not Stored & PCM Failure EEPROM Write Denied - Test FC-14A
  1. Turn ignition on. Using DRB-II, perform SRI memory test. If DRB-II displays WRITE FAILURE, replace PCM. Perform TEST VER-1. If DRB-II displays WRITE REFUSED, go to step 2). If DRB-II displays SRI MILEAGE INVALID, update mileage and retest SRI memory. Perform TEST VER-1. If none of these messages are displayed, compare SRI mileage stored with mileage on odometer. If mileage is same between SRI memory and odometer, retest SRI memory. If mileage differs, update SRI mileage and retest SRI memory. Perform TEST VER-1.
  2. If DRB-II displayed WRITE REFUSED, PCM was busy. Using DRB-II, perform SRI memory test. Retest SRI memory 2 more times if necessary. If WRITE REFUSED fault returned, replace PCM. Perform TEST VER-1. If WRITE REFUSED fault did not return, test is complete. Perform TEST VER-1.
User Feedback
There are no reviews to display.
