Fuel Gauge Replacement Sender
(1 review)
For all of you that are running around with a broken fuel gauge that reads incorrect level  than actual fuel level, there is a replacement sender that you can get from the Dodge Dealer.
Part Number: 4897669AB (For 2000-2002 Dodge Ram)
Part number # 4897669AC (Updated fuel sender part number - Oct, 2020 @Towrigdually)
Approximate Cost: $68.45
I was warned by the Dodge Dealer than the actually part number may vary and you should contact a local Dodge Dealer and provide them with the VIN number so to get the proper part for your application. As for requiring an In-Tank Lift pump you do not and don't let them sell you one either its' not required
fuel-sender.jpg.7277e1f3a6e736ae33326c0f
User Feedback
Recommended Comments
