Cubby Hole High Idle / MPG Fooler
Mopar1973man.com no longer sells a specific Cubby hole mount, but we do provide the below template if you wish to make one yourself.  You can use the current PCB mounted switch with this faceplate.
As for installing you need to carefully pull your dash bezel from the dash and remove it. Then taking 3 screws out holding the cubby pocket in place and remove. Also remove the 4 screws holding the HVAC controls. This will give you room to routing the wires across the dash.
Now mount the face to the cubby and using the supplied screws and nylon spacers.
Continue to route the wires over to the bulk head.
Then this part is bit tricky and requires patience carefully route the plug through the rubber boot of the bulkhead connector. The bulkhead connector inside can be released from it mount and might give you a few more inches of work room for a single hand.
Now route the connector to the proper placements. Black ECT to the front of the engine and the Grey IAT connectors to the rear of the engine. Now unplug both ECT and IAT and plug in the fooler cables.
ECT
IAT
Then reassemble your Dash.
The only thing I didn't hook up yet was the LED power.
User Feedback
More options...
   2 of 2 members found this review helpful 2 / 2 members
Had mine for a while now, nice added feature to the truck. :thumb1:
