Welcome To Mopar1973Man.Com LLC
We are privately owned, with access to a professional Diesel Mechanic, who can provide additional support for Dodge Ram Cummins Diesel vehicles. Many detailed information is FREE and available to read. However, in order to interact directly with our Diesel Mechanic, Michael, by phone, via zoom, or as the web-based option, Subscription Plans are offered that will enable these and other features.  Go to the Subscription Page and Select a desired plan. At any time you wish to cancel the Subscription, click Subscription Page, select the 'Cancel' button, and it will be canceled. For your convenience, all subscriptions are on auto-renewal.
High Idle Switch
High Idle Switch
9 Cummins articles in this category
  1. Mopar1973Man ·
    How to detect if the Cummins 24v VP44 ECM has been enabled for high idle? It not to hard to check to see if you have high idle software present. The only thing you need is a resistor that is a 39k ohm or greater up to no more than 100k ohm resistor. The other requirement is to have a cold engine. Engine coolant temperature must be below 140*F for this test to work properly. Just unplug the IAT sensor and take your resistor and fold the legs over and insert into th
    • 0 comments
    • 7,037 views
  2. Me78569 ·
    Mechanical High Idle for All Cummins Trucks Here is another version of high idle you can produce for you dodge Cummins. A member over at Cummins Forum came to me with his version of high idle. Thank you WJBell for your information and allowing me to post here on my site... WJBell's High Idle Write Up Original Information is here. http://www.cumminsforum.com/forum/98-5-02-powertrain/111278-mechanical-high-idle-bomb-completed.html Since seeing Mopar Mans high idle I've been w
    Me78569
    • 0 comments
    • 4,888 views
  3. Me78569 ·
    Mopar1973Man Cummins High Idle Switch install Parts supplied:   Switch x 1   Switch Harness x 1   Switch Face Sticker x 2 Tools Needed: Drill + 3/8” bit Cleaning Wipe Pliers Small Flathead Installing: First unplug the batteries to prevent any shorting while installing. The Mopar1973Man High Idle Switch can be mounted anywhere that the harness will reach. The Harness is a total of 10’ long. 4 feet of the harness is re
    Me78569
    • 6 comments
    • 13,489 views
  4. Mopar1973Man ·
    Cubby Hole High Idle / MPG Fooler Mopar1973man.com no longer sells a specific Cubby hole mount, but we do provide the below template if you wish to make one yourself.  You can use the current PCB mounted switch with this faceplate.   As for installing you need to carefully pull your dash bezel from the dash and remove it. Then taking 3 screws out holding the cubby pocket in place and remove. Also remove the 4 screws holding the HVAC controls. This will give you room to routin
    • 0 comments
    • 6,935 views
  5. Me78569 ·
    Mopar1973Man.Com High Idle / MPG Fooler Overhead Console Installation Ed Grafton sent me a Mopar1973Man High Idle switch for me to install into my overhead console, and do a write-up on it  This is for guys that have no where else to put it due to too many gauges, or in the rare case like Jigabop who has too many options Ed Grafton extended the length of the wiring to allow for the wires to be run from the overhead console, under the headliner, down the A pillar, and into the engine ba
    Me78569
    • 0 comments
    • 3,751 views
  6. TFaoro ·
    To start with make sure you have the supplies to complete the install: 1. Wire crimpers and strippers 2. Wire connectors 3. Gauge pod for the steering wheel 4. electrical tape 5. Add-a-circuit fusible tap 6. Tons of zip ties 7. Wire connectors with a round end for a screw or bolt 8. Two sided tape (Usually comes with gauge mount) 9. Fuses 10. Sockets, screwdrivers, dikes, razor blade   Next the install!
    TFaoro
    • 0 comments
    • 62,154 views
  7. Mopar1973Man ·
    Operating Instructions Once the high idle kit is installed its ready for use if the ECM has had the High Idle Feature Enabled, the Dealer can enable this feature, or a Smarty can flash the High Idle into the ECM.  There is a Dodge TSB Covering what needs to be done, Dodge High Idle TSB   You can view the Install Article Here, mopar1973man.com High Idle Switch Install you can buy a High Idle Switch in our Store -    General Operation It's always suggested you s
    • 1 comment
    • 10,534 views
  8. Mopar1973Man ·
    Date: September 3, 2001 Models: 1998 1/2-2002 BR/BE Ram Trucks (2nd Gen Cummins, 1998 .5, 1999, 2000, 2001, 2002) NOTE: THIS BULLETIN APPLIES TO ALL RAM TRUCKS BUILT AFTER DECEMBER 17,1997 AND EQUIPPED WITH THE 24-VALVE 5.9L CUMMINS DIESEL ENGINE. Discussion: This bulletin involves selectively erasing and reprogramming the Engine Control Module (ECM) with new software (Cal 55Tl8, 57Tl1, 56Tl3, 59T7b, and 59T8b.) Symptom/Condition: Extended idle operation, espec
    • 0 comments
    • 10,599 views
  9. Mopar1973Man ·
    Mopar1973Man.Com the Mopar1973man.com High idle switch is sold through the Forum Store.   you can get to that product and others through this link      If you are having problems getting the High Idle enabled on your truck you may rent a Smarty from Diesel Auto Power. Smarty Rental For High Idle Enabling
    • 0 comments
    • 3,508 views
