batteries slowly losing charge
To start off it off I will say I just replaced both my batteries with Interstate green top batteries about 7 months ago that have higher CA and CCAs than the last set of walmart batteries I had.
Problem is that I got a new(er) truck to drive around for better fuel economy and comfort so now my truck in sig, 2001 ram 2500, is losing charge after sitting for a little while. I actually started to notice prior to getting my new truck about 3 weeks ago that even after it sat over a 2 day weekend it seemed like it took a few more turns to get it to start. This time it sat for about 2 weeks and it was completely dead when I tried to drive it this past Sunday.
Any guesses on what could be slowly draining the batteries? I do not have any aftermarket accessories running when the truck is off. And besides a regular pioneer radio in the dash that is the only aftermarket interior change which I put in a few years ago.
  • Replies 1
  • Views 1.1k
You need to pull one fuse at a time and measure the amperage draw one circuit at a time. When you find the circuit with the heavy load you can now isolate the problem. Make sure to remove any accessory connections to the battery directly.
Power Distribution wiring map 1999 Dodge Ram
