2005 Ram 3500 Quad Cab, Long Box, SRW, SLT, 4x4
Built 10/04; In Service 11/04
Bought Nov 2007 with 10,307 miles
Sold on 3/18/2019 with 141,854 miles
Drivetrain
Cummins 600
NV5600
NV271transfer case
Engine Mods
Built by Big Twin Diesel 12/13
Smarty Touch UDC PRO, tuned by me
Garrett Stage 2 GT3782R
Balanced Rotating Assembly
Hamilton Cam's 178/208/110
Hamilton 103# Valve Springs
Hamilton 24V HD Pushrods
Cummins 24V 1.3" tappets
QSB 480 Pistons
BBi Stage 1 MY03 Injectors
ATS 2-piece Exhaust Manifold
ARP Series 2000 Head Studs
Fluidampr
Southbend Con-OFE
Southbend Hydraulics
PacBrake PRXB
Turbo Performance Products Exhaust Manifold/Turbo Blankets
Airaid Modular Intake Tube
GDP Flo-Pro Intake Horn
GDP Air Boss Intake Plenum
GDP Grid Heater Delete (MAY-SEP)
GDP Big-Line Kit
DT Pro Fab Steering Box Brace
Kitty MIA
Donaldson M090544 Muffler
Flo-Pro 4" exhaust
Home Depot CAI/WAI
Gauges
ISSPRO EV2's Gauges w/ warning lights
-Boost (>38 psi)
-EGT (>1250°)
-Fuel Pressure (<3 psi)
-Exhaust Brake/Drive Pressure (>65 psi)
-Oil Pressure (<15 psi)
-Oil Temp
MADS MM3
Filters and Fluids
Engine
-Mopar 4" Pleat OEM Air Filter
-Amsoil AME 15w-40
-Donaldson DBL7349 Full-Flow
-Amsoil EaBP110 Bypass Filter mounted on a BMK-11
Trans
-Amsoil MTF 5w-30
Xcase
-Amsoil ATF
Diffs
-Amsoil SVG 75w-90
Power Steering/Brake Hydraulics
-Amsoil ATF
Coolant
-Final Charge Extended Life 50:50
-Donaldson ECF4085 Coolant Filter
Fuel Filtration
-Baldwin BF1212
-Mopar Severe Duty Filtration Kit, with heater and WIF sensor wiring
-Baldwin PF7977 OE Style 5um filter
-Fleetguard FF5814 3um Fuel Filter, Mounted to the GDP Horn
Suspension
Top Gun Customz 1” Front Level
Firestone Ride-Rite Rear Airbags
Rear Hellwig Anti-Sway Bar
Dynatrac Pro Steer Ball Joints
Yukon Spin Free Hubs, with Yukon Lockouts
Bilstein 5100's
MAXX Links Sway Bar links
Wheels/Tires
245/70R19.5 M608z LRG on Black Vision Type 81 Heavy Haulers with Counteract Balance Beads
255/80R17 LRE Cooper ST MAXX on OEM Forged Alum wheels (hunting tire)
Do-Dads
SiriusXM OynX Satellite Radio
ViAir 450C compressor
Cobra 75WX-ST CB
Weather Guard Tool box
Mopar Running Boards
Mopar Vent Visors
Fender Flares
Garmin Nuvi 1200
Garmin eTrex Vista C
Mopar Winter Front
Max Brake Hydraulic over Electric Brake Controller
Titan Class V Receiver
Brite Box with Fog Light Control and Fogzilla
Mag Hytec Front/Rear Diff Covers
Fast Coolers
OEM Clear Cab Lights
Duraflaps
Geno's Console Cup Holder
Current Dyno
415/850 MM3 UDC Pro
Usage Stats
Best MPG: 21.54
Avg MPH: 32.6
The day I got her.
Installs/Writeups
3rd Gen Fuel Filter Install
3rd Gen Home Depot CAI
3rd Gen Power Steering Flush
3rd Gen Coolant Flush
3rd Gen Oil Bypass Filter Install
Garrett Powermax Stage 2 GT3782R Install/Review
Edited by AH64ID
  • Views 12.6k
