- Replies 7
- Views 1.7k
IBMobile 4 posts
ryanhawkins 3 posts
Popular Days
You should have earth (ground) when you probe the BL/LG (black/ light green) of the O/D switch. This wire is connected to earth at the inside left cowl near left hand drive steering column.
hey i know this has topic has popped up heaps of times though im running out of ideas on mine 1999 cummins converted to right hand drive , i have replaced both ecm and pcm with remans from auto computer exchange, replaced transmission sensors solenoids.. speedo sensor on diff with new 5mm wires overkill i know, up to plug behind left wheel ive had all harness on engine stripped when i was diagnosing ecm issue, just recently was when i changed the pcm hoping that'd be the overdrive issue prior to that i had the switch on the dash mod so i know the transmission itself isn't the issue i spliced into wire for the o/d at the pcm so i know the wiring down from there is ok and i put in a new transmission plug, interestingly enough the key fob is slow to react and doesn't flash indicators and immobilizer not working the over head console no longer works nor does the o/d off switch i probed both terminals at the o/d off switch with earth and nothing happened and dash light does work, my thermostat is stuck open however ive had it up to about 75-80 degrees c with no luck would it need to be warmer than that? new battery's earths cleaned and run a flap disc over them wrapped some foil round the wire over the alternator, new tps sensor map sensor oil pressure sensor transmission relay, any idea's?
