February 13, 20206 yr Ive have searched High and Low and can Not find an answer to this. But to make sure I understand. I have a quadzilla adrenaline V2 installed in the truck. I have tried to make it high idle with parking brake ect. when it was cold as ever. No high idle I have purchased a Moparman high idle switch from DAP and look to install it. Can i install it with current quadzilla plugged in everywhere? And If i need to flash the Computer to enable high idle either with a smarty or a dealer.... can quadzilla stay plugged in? If this is a dupe post please let me know. Thanks for all the infinite wisdom you guys have on here. Finally signing up Truck is a 2001 24v 99% stock with a rebuilt auto.
February 13, 20206 yr The quad doesn't care about an ecm flash. You can install them side by side, just make sure you disable the quadzilla high idle.
No high idle
