- Replies 13
- Views 3.1k
Zacharynels 7 posts
ISX 3 posts
MnTom 2 posts
Northwoods 1 post
I have a small oil leak or two on my truck. The crank seal leaks a little and i think the timing cover gasket may be as well. I don't know for sure because I've yet to rip the front end off and take it all apart, because of my broken ratchets and lack of air tools. I am afraid that maybe my vacuum pump may in fact be one cause of oil seepage as well. I noticed a few weeks ago, that there was a slight "film" on a transparent fuse I have under-hood. I wiped it and it looked like it could have been exhaust leak collecting, but I now realize that it is some soft of oil hitting my radiator fan perhaps... Could this be? There is light oil gathering on the radiator hose that crosses from rad. to block on the bend. It is also gathering, right by the fan blade, on the reservoir.My vent tube seems to be leaking a drop after driving, but there is oil on a few things. So it is hard to decipher where it is coming from.Any advice would be awesome.1995 2500 4x4 5 speed fyi
