2004 3500 Manual Trans Conversion (APPS)
I'm attempting to use a 05-06 pedal mounted APPS. I bought the Timbo Kit and have it wired directly to the ECM.
This is the wiring diagram I came up with:
APPS Position   Description         ECM Location
#1                    5 Volt Supply      #33 (ECM C2)
#2                    APPS 2 Signal     #16 (ECM C1)
#3                    APPS 2 Return    #48 (ECM C2)
#4                    APPS 1 Return    #33 (ECM C1)
#5                    APPS 1 Signal     #14 (ECM C1)
#6                    5 Volt Supply     #42 (ECM C1)
However I am getting P2121 & P2128
I have tried two different pedal apps assemblies (APS312)
I have done the re-learn procedure over a dozen times.
ECM has been calibrated to a 2004 Manual calibration.
I have also attached two data log pictures. The first is with throttle off and the second is with throttle fully pressed.
Not sure if I am missing something or doing something completely wrong.
Any advice would be greatly appreciated. Thanks in advance!
  • Replies 2
  • Views 1.9k
Problem has been resolved.
Switched #2 & #5 at the APPS connector from the suggestion of another forum member (cumminsturbofreak).
That fixed my issue.
Thank you for the article Mopar1973Man. If this hadn't worked then I was suspecting a faulty ECM
