2006 Dodge Ram 3500 - Blower Motor issue
This is just a quickie fix for a customer that came to me asking if I could fix there A/C & heat the blower would randomly work or not work. Yeah I started at the wrong end testing the TIPM first which I found out everything was working properly. Then I moved to the blower motor itself. After removing the blower motor from the HVAC case then everything made sense. Check out the Quick TikTok.
As you now see that TikTok videos are now rendered properly on the website software. There will be more of these in the future.
  • Views 1.6k
No posts to show
