So i just did new head bolts this weekend on my truck. I got grade 12.9 allen head bolts and grade 12.9 washers off mcmaster carr for 84 bucks. The bolts are made in italy and seem like real good quality. I replaced my stock bolts one at a time front to back torquing the bolts to 120ft lbs each time i changed one. I used arp fastener lube and tried to remove as much oil from the holes under the valve cover that had oil in them. This is where i might have messed up by not getting all the oil out of the holes. So 90 percent of the bolts torqued down just fine but some seemed to have a little slip like they would spin slightly more before clicking . Possibly due to oil on the threads. Now i shouldnt have listened to some of the morons on this forum im on on facebook. Some people were saying to do a hot retorque so i started to and the bolts outside of the head would click almost instantly where some of the bolts under the cover seemed like they would keep spinning if i kept at it i got like a 1/4 turn to a half turn out of some bolts and said this just doesnt feel right. So i quit while i was ahaid i didnt want to yeild the bolts or pull threads. My main question is it possible i gained some life span on my 315k mile head gasket by doing this? I wanted to be pro active and try to tighten things up with stronger bolts in the hope of making my head gasket live a longer life. I will say though these allen bolts seem pretty dam stout, the fact the shank is larger is a pluss and the less threads i would think is also a plus scince more threads outside of a hole just means a smaller shank
- Replies 7
- Views 877
daav544 4 posts
Tractorman 3 posts
