- Replies 5
- Views 1.9k
Sycostang67 4 posts
IBMobile 1 post
Drove the truck to work last week, noticed the truck vibrating at 60mph. It went away when I sped up to get on the interstate. When I left work I noticed it at 35mph and went away by 40. It was off and on at 60 on the rest of the way home. Under load or coasting didn’t seem to matter either. It doesn’t feel like it’s in the steering, just through the rest of the truck. I did check the rear drive shaft and everything felt tight. I had the front and rear shafts rebuilt and balanced when the trans was built about 50k miles ago. The only thing I know is a little worn is my track bar, was mentioned when I had the trans serviced last year. The heat has kept me from doing any real investigating so thankfully it’s not a daily driver. Just trying to think of something that makes sense as I really thought it would have been a drive shaft issue.
