24 Valve Swap
New here,
Swapped a 24v with a DCS standalone harness into a Land Cruiser. Fires up idles, but NO throttle.  Motor was running and driving before swap.
APPS is within range,, new batteries, connectors, cables etc.  but not getting a signal back to the ECM.  Scanner shows ZERO through the OBDII, no change when operating the throttle.
Changed sensor .6 to 4.1V with multimeter at sensor and all other parameters are within ranges and check out.
0122 Code- Low Voltage on scanner.
Any help on this.  I'm hoping the ECM is not bad.
Jason
Edited by TRAIL TAILOR
  • Replies 2
  • Views 5.7k
  • TRAIL TAILOR
    TRAIL TAILOR
    Found out it was a harness issue. Company shipped out another and all running accordingly.     https://studio.youtube.com/video/mVtn8sBoItM/edit   Thanks @Mopar1973Man for the
