Water methanol for mpg.
Looking for experience with water methanol. Done a lot of reading on it but haven't seen anyone do what I'm thinking of doing. (Probably because it's not smart for most people)
I would like to try and experiment with running no intercooler and using only water methanol to control temps.
Im hoping this will allow for higher inlet temps at low load and a shorter better flowing intake side netting some better mpgs. Im really curious how the quadzilla will play with water methanol.
According to my math the intercooler removes 3000btu per min at 30 psi of boost. Water removes 970 btu per lbs methanol a little less but flashes at a lower temp. So I should need about 1400ml worth of injection to keep 30 psi cool Im thinking of running 2 stages each 750 ml one at 10 psi one at 20 and drilling and tapping the volute of the turbo for the location. (Should be the hottest part of the system and it gives similar results as running pre turbo without the risk of destroying your impeller. Im hoping to incorporate a section of clear tygon tubing or plastic before the intake horn to see how much is actually flashing to gas. And I'll fab up a intake horn and clock the turbo to run similar to how 1st gens did it. Right over the valve cover. I'm not shure how cylinder distribution will work and might have to center or run dual intake horns to get air flow evenly distributed.
I know slead pullers run crazy pressure (I'm pretty certain pressure washers coupled to a starter motor) but I don't know how much they flow. Is their a saturation limit to how much I can inject? How do I tell when I'm getting close? Hydrolocking is not something I'd like to do lol. What inlet temp is the cummins most happy with?
Old non intercooled first gens made 10-15 psi with no intercooler so I'm curious with a more efficient turbo a better flowing head and quadzilla what's going to happen!
Let me know what yall think and thanks for reading.
  • Replies 27
  • Views 4.4k
  • OK so looking at my math I messed up twice but somehow got close. Lol cfm for a hx 35 is listed as close to 600cfm Instead of 900cfm. And my temp was off that output calc was really helpful. It's show
  • Will absolutely be careful with it. This is indeed my daily driver and If im being honest with myself at all I will be converting back to a intercooler when this doesn't work. But I have to try and fa
  • Build is progressing slowly then id like but trying to do it right the first time. Slow transferring all the parts to the new long block but got the turbo drilled tapped for water methanol and gasket
Day 1 overheat with mechanical fan ( no shroud) install electrical fan set up and wire
Day 2 blow brake line going 80 mph during engine break in
Day 3 transmission cooler line is severed internally ( routed different then previous and the sharp end of the tube cut the line) work loved the giant red puddle
Day 4 finally find source of overheating to be bad thermostat ( thought electric fans were in effective)
Today's mission find source of hard start ( fuel leak somewhere) pressurized tank to about 10 psi and got fuel from above tank no where else pulled valve cover and verified no injector leaks. Next thought is connector tube o ring but not sure how to test besides smoke on start up.
The overheating is not good on a fresh rebuild, as it expands all the parts during the overheat. Strange to see a Cummins overheat without a fan. I ran several winters without a fan clutch and fan assembly.
Might be the call for a full inspection of all thebrake lines. You might hunt around; there are a few here that have replaced with stainless steel brake lines and are using all premade brake lines.
Opps. Yeah, we all make weird mistakes.
The
The NAPA 375-190 thermostat has treated me well. I typically always put a fresh thermostat in with fresh coolant. When you are changing coolant every 60k to 70k roughly, so your additive package doesn't degrade. (pH stabilizer, etc.)
Yeah the overheating was not good. Had to help a friend in need and rushed the truck a bit. I believe it was a large amount of trapped air in the head I had hadnot burped out during the cam break in. Didn't let oil temp exceed 200 degrees but I know i didn't do anything any good.
And yes I replaced all the brake lines with stainless was only 185$ for the lines and about 2 hrs of work.. I highly recommend inspecting the clamp under the brake booster where it mounts to the frame. Thats where mine rotted out at the clamp holds water that splashes up from the road.
The thermostat was a murry brand new 200 degree but for whatever reason was missing the little air jigglers ( small bypass holes with metal tabs in them) i think that caused it to air bind in that section.
Tip for next time: leave the thermostat out of the head till the coolant is full to that point. Install the thermostat and top off with more 50/50 mix coolant. 200℉ is not bad for oil temperature, but was the block temperature hotter?
Could you do a write up for the brake lines if possible? I'll make it worth your while.
200℉ Thermostat. So you are going for the higher temperature as well. Let me know how its working for you. I'm still running my Gates 200℉ and no issues to report. Excellent heat in the wintertime and excellent idle performance after extended idle times, it might get a bit smoky the first day till it fully warms up. I'm still running so efficiently that idle will not even warm up the block to even close to open the thermostat (Coolant temps 155℉ to 170℉ and outside temp of barely 35℉)
Yeah I'll for sure do that next time lol. Hopefully I wont waste the life time coolant I added as well.
I'll try and do a write up on the brake lines I should have taken more pictures when doing it.
And yeah these trucks are shockingly efficient. I have yet to turn my electric fans on here in texas
