Unable to prime with working lift pump.
- Replies 8
- Views 4k
Mopar1973Man 4 posts
yohon 4 posts
Need help figuring out these new fangled 6.7 a friend of mine at work asked if I could look over his truck he just got an oil change at a jiffy lube and it was running rough after. I drive a older 24v and work on it constantly so I figured they cant be too difficult or different.
Check the engine bay fuel filter first thing and sure as **** no o ring on the fuel filter cap and it was insanely tight. Bought a o ring threw it in ( tightened the bolts that hold the housing to the block was missing a bolt and others were loose) crank the key over to prime and nothing. Do a little googling pull the lid of and look at level and nothing no priming. Checked the lines at the pre filter ( one under the bed) and something is pumping unhooked and verified fuel in and fuel out when key is cycled. Got copious amounts of fuel rained over me. Re installed and still no prime.
I am completely lost. He drove the truck 30 min to work after the oil /filter change but when we fixed the air leak on the filter cap absolutely no prime but the lift pump is pumping? Is their a check valve suck closed or a regulator that is not letting fuel to the filter housing. Any help is appreciated
Sorry forgot to mention truck in question is a 2012 2500 4x4 crew cab that has been deleted
