HDPE washer fluid reservoir crack repair
I have a 2" crack in my washer fluid reservoir. Plastic weld repair is the way I'd like to go. I see info online about techniques, but thought I should check here for actual experience welding these since I'm having trouble finding replacement reservoirs and I may only get one shot at the repair.
Have any of you successfully repaired a crack on this reservoir? Any tips if so? thanks.
  • Replies 3
  • Views 190
  • Stanley
    Stanley
    LMC truck has them also. Here ya go. Lmc truck washer res link
I wouldn't even bother with trying to fix it. A new one is only like $30 or you could find a used one on FB market place for $5-$10...
Save yourself the headache. cheers
The only Rockauto option was out of stock, and searching that PN turned up nothing. Nothing on Geno's, so I concluded that it would be hard to find.
Looking again this morning, I found one at Partsgeek for $40. That'll work.
i'll probably try to solder weld the original just to work on a skill though. Might need it sometime.
