I recently replaced my clutch and since I was in there I decided to reseal the cam plug, rear main seal retainer and the seal itself. 2001 24V HO is the patient.
I’m going to show you my way of doing it. Although there are many ways to do these and other ways work fine I suppose but since I own the OEM tools I’d thought I’d share how it’s done.
Once the starter, clutch & flywheel are removed we need to remove the 8 bolts and drop the bellhousing adapter off.
Then unbolt the seal retainer from the block and oil pan. Discard old seal.
The cam plug (Cummins # 3900687) needs a 3/8” hole drilled in the center and can be removed with a heel bar.
Clean all the mating surfaces well with a scotch-brite pad, brake clean and shop towel.
The cam plug comes from Cummins with a sealing oring but it’s never guaranteed to seal since you can’t see it behind the plug.
Lay some RTV on the inside edge (be careful not to smoother the cam). Put the new plug in and hit the center with a dead blow hammer, it’ll expand and sit in place. Then put some RTV on the outside for insurance.
This tool is crucial as it ensures the retainer is centered correctly in relation to the crankshaft. Since the retainer doesn’t have alignment dowels - if the retainer is off a smidge the seal will leak.
The reason I like the retainer tool is you can put the retainer back onto the block with the seal out and set it “on top” of the pan. If the seal is installed on the retainer and you slide it on as I’ve seen in some videos the RTV can just scrap off and thus not making a good seal on the oil pan.
Next, install unitized seal Cummins # 3824078 with its mating installer Cummins # 3926126. This ensures the seal is installed to correct depth and evenly. If you have any scoring/gouging to the crank surface a regular teflon lip seal will get chewed up and you’re gonna have a bad day.
Lastly, reinstall the bellhousing adapter and torque to 44 ft/lbs and the flywheel to 102 ft/lbs respectively.
View full Cummins article
