Shuttle shift fix = new solenoid
I have what I believe is the "shuttle shift" in the lower gears. More noticeable when the tranny is cold and when putt putting around town. I ordered a new solenoid and filter from transmissionpartsusa.com. I got what I believe is not the BW part everyone on the "other forum" is ranting and raving about but I'm good with it. My local transtar dealer wanted $80 for the bw part, found it online for 65 and I paid 40 for what appears to be the oem unit. I'm told my pan gasket is reusable and that I'll need about 7 quarts of ATF+4 to top the tranny off when finished. Am I missing anything? Also, I have access the torque wrench needed for the band adjustment. As read countless posts of people screwing their trannys up adjusting bands should I just leave it be? I'm sure most is due to "operator error" and I'm confident I could do it without making a mistake but I've never felt a slip, even when towing my behemoth. Truck has 85k on it.
  • Replies 4
  • Views 4.2k
No advice? What if I say I plan on using Autozone brand ATF+4........oh yeah, I said it....:hyper:
Sounds like you are on the right track. Next would be the in line noise filters and a TIMBO apps. What is the "BW" part your referring to? OH yeah please fill in you sig so we know what year/ description vehicle we are helping you diagnos.
Sorry, It's filled in. Borg Warner makes a replacement governor pressure solenoid. A new solenoid is supposed to cure the 48re 1-2,2-3 shuttle shift. Don't need the BW solenoid to cure the problem, an OEM will too, it's just supposed to be a better solenoid. What is a "in line noise filter and Timbo Apps? Is that a 47re thing?
Yep, as I didn't know what year vehicle you had the early 03 had a 47 re and 03.5 and newer have the 48re.
