Anything wrong with this idea.Going to have a small 1 gallon tank and pump up front for my methanol injection. But I want a larger reservoir so was going to GRAVITY feed a 7 GALLON sitting in my truck bed to the front via 1/4" OD tubing .... Anything wrong with the idea ? CLICK PIC BELOWBetter ideas ? post-10132-138698180618_thumb.jpg
  • Replies 3
  • Views 1.8k
Why do you need the 1 gallon tank at all?
Yeah thats how I originally ran it - with my stage 1 kit - but this way I can keep the 1 gallon tank which looks cool and the pump up front - rather than pushing h20 over 20ft. from bed.
Just make sure the one is higher than the other, also if the heights cant be far enough apart to ensure a constant supply, maybe a check vale to prevent the water from sloshing front tank to back tank.
