Looking for Staff Members
I've been finding a lot of stuff across the web lately but geeeeez its a pain to find it all. I'm compiling everything I have found into this thread. What I have found is really good info and tells just about everything about the p7100. This concerns specs/teardown diagrams/all kinds of stuff. Clicking on these "[source]" takes you to where I found it. I don't like stealing people's info without giving them credit.
Pump Specs
There are 2 number plates on the P7100, one is underneath the throttle plate on the drivers side of the pump so you have to take the 3-10mm screws out and take that plate off to see it. That number plate concerns the front half of the pump. The other plate is on the very back of the pump and dictates governor characteristics.
The numbers on the back of the pump will be something like RQV400...1150PA1172K
Which decodes to:
R = Governor
Q = Transverse spring
V = Variable speed governor
400 = Rated minimum speed (idling speed = 1/2 engine speed, engine idle 800RPM) ... = controlled range
1150 = Rated maximum speed (= 1/2 engine speed, engine max speed = 2300RPM)
P = P series pump designation
A = Modification letter
117 = Type code
2 = Suffix
K = Torque matching by characteristic.
[source]
The numbers on the side of the pump (under the plate) will look like this:
PES6P110A120RS7213
0 402 736 906
96628 08721
The first one can be decoded like this:
PES6P -Denotes number of cylinders and Basic Pump Model
110 -Denotes Barrel & Plunger Size in MM
A120RS -Denotes Cam rotation direction (Cummins is Right)
7213 -Denotes Pump series (2000, 3000, 7000, etc)
[source]
The next line of numbers seem to be a cummins lookup thing, but this website has put together a list of them, among other things. http://www.chathamfuel.on.ca/generic.asp?pg=appl_59&ti=Applications - Cummins 5.9
Here is that chart in a little easier to read format.
Posted Image
Timing Lift values are found here.
Timing Lift values expanded version.
Injector Size Specs.
Delivery Valve Flow Specs.
Diagrams/Pics
Big article on how the P7100 works (PDF)
P7100 Dissected
Posted Image
Posted Image
Posted Image
[source]
Posted Image
[source]
Posted Image
Posted Image
Posted Image
Posted Image
[source]
Delivery Valve Dissected
Injector Material
Injector Dissected
That should do it for specs and diagrams. More stuff to come another day..
  • Replies 7
  • Views 20.8k
Out of them numbers how do i tell if it is a 215 or a 160 or 180 ?
Do i have this correct ? 913=215 pump. 912 and 911 =180pump. 854=160pump.841=175pump.
Yep, I redid their chart if you scroll back up to the first post (I edited it). Their table is a little caddywompus.
I dont see a 402 736 838 on the list. Could you list the non dodge pumps? like the buses p pumps. I think the 838 is a dodge but i would like to learn more about the non dodge p pumps. Thanks.
That's a 160hp pump. If you search the whole number you can find them but I will see what I can do about a complete list. I found out the other day that the rv ppumps from 94-97 had 235hp and 605tq stock, would be nice to find all the other pumps they made and their ratings.
