Front hub replacement/axle housing seal
- Replies 7
- Views 2.7k
CUMMINSDIESELPWR 3 posts
silverram323 2 posts
hex0rz 2 posts
Ok...I replaced both front hubs a few weeks ago. I have only driven it once since...Iv'e been waiting to get the money for the tie rod and drag link...blah blah. Well, I noticed I had diff fluid coming out of the axle tube on the pass side...leaking all over the bottom ball joint. I took everything back apart and cleaned the best I could in the tube before putting the axle back in. I put it all back together but I don't know if it will seal this time. It appears there is a seal close to the diff that seals around the inner axle. Hopefully it was just some debris keeping it from sealing properly. If not...I guess I need to change that rubber seal...anyone ever done this?
