fuel return system changes
- Replies 4
- Views 2.4k
Mopar1973Man 2 posts
1dumrednek 2 posts
this spring i plan on dropping the tank out of my 02. i already have an airdog with a 1/2" draw straw but imn sick of low level slosh issues. im going to get a vulcan draw straw V. but while im at it, i wanna run 1/2" return lines too and have em dump into the canister rather than the filler neck. i was just wondering what size the banjo return fittings are? so i can put a jic fitting on the back of the head like the airdog supply. and from what ive found i need a barbed banjo fitting fo rthe return off the pump because of the pressure valve in the bolt. just dont know what size for that either.thanks
