Remove a leaf????
Question...has anyone with airbags ever removed the bottom most leaf in the pack? I'm just brainstorming ideas...Here is a photo of the leaf. Sent from my iPhone using Tapatalk
  • Replies 2
  • Views 1.7k
Not to side track but you need to wash the salt off... :duh:I don't run air bags... I've never found a reason to run them yet... I rarely sit down even on the overloads...
Wash, we wish we could. Our temperature swings 40 degrees in 8 hours here. Just when we think we can wash our vehicles we'll go below 0. Then it warms up a bit, the roads get icy, then they salt, then we think we can wash then it gets cold again and the cycle continues!!! Ugh!!Yes. I travel a bit heavy. With a canopy, tool box filled and a slip tank I almost always sitting on the upper overloads and on that lower thick leave. I'm starting to think my stiff ride while loaded might improve if I install some bags and ditch that lower spring?!!!Just thinking. Sent from my iPhone using Tapatalk
