VALVE COVER BOLTS TORQUE SETTING
ANYONE KNOW THE TORQUE SPEC FOR THE VALVE COVER BOLTS ON 2nd GEN 24 VALVETHANKS!!
  • Replies 3
  • Views 6k
as per "2001 DODGE ram FSM"(3) Install the remaining bolts and isolators. Startingwith the center bolt, torque in a circular patternto 24 N·m (18 ft. lbs.).
Thank you for the info. :thumbsup
Hey,Don't over tighten them or the valve cover can get warped and leak!!!!!!!!! :mad Later,Winslow
