Last weekend while driving my truck I started noticing a weird noise coming from the front end of my truck while nearing a stop sign. Almost like a deep vibration type of noise. I haven't taken anything apart yet but it seems like there is still plenty of pad left:shrug:. It's still doing it and they feel kind of grabby now.Luke
  • Replies 2
  • Views 1.4k
That sounds like it may be a caliper piston starting to stick and applying pressure a little sideways on the pad. Do the brakes pull to one side or the other? You may also want to pick up a set of bushings to make sure they slide properly. http://napaonline.com/Catalog/CatalogItemDetail.aspx?A=UBP82999A_0326754558&An=599001+101998+50022+2022010+26528&Ar=AND(P_RecType%3aA)
Got to get a good look under it yesterday. pass side rotor is trashed. Time for a brake job.Luke
