High idle set up
  • Replies 4
  • Views 2k
Prowelder is a little too busy,is there anybody else building those units?
I just barely finished building mine. It honestly isn't hard, the connectors you'll need can be purchased from Casper's electronics and everything else I bought from digikey. If you've got a couple hours you can make one that'll work without anything tougher than soldering and drilling a box to mount the switches in
