Cummins vs V10 trannys
What is the difference between a Cummins and V10 tranny? Governor for shift points? TC? the internals should be the same for strength, I think?
  • Replies 2
  • Views 2.3k
IIRC, theyre the same. Both are speed/pressure controlled for shifting. Output shaft speed sensor and governor pressure. Sent from my SPH-L710 using Tapatalk 2
The only thing Im aware of that could be different (depending on the year) would be the valvebody. You would either have to find a trans of the same year or swap vb's
