Looking for Staff Members
Power steering pump / Hydroboost / power steering box / cooler hose sequence help!!!
Ok guys i hope its ok to post this in this forum but what i have is a 12v cummins swapped into a 97 crew cab chevy dually. I am to the task of hooking up hoses and i am puzzled at which hose goes where! I guess i need to know what sequence your truck uses or if someone could give me detailed help as which hose goes where in some sort of a methodical approach it would help me out tremendously..I havent thought about it a whole lot but when i was trying to make sense of it and was thinking about the whole high pressure/ low pressure side and which one should go where i got a bit taken back by the complexity... when i looked at the rear of my power steering pump and it had THREE hoses hanging off of it, i stopped. Im calling in the experts! any help will be appreciated....
  • Replies 1
  • Views 1.6k
The third hose off your PS Pump should be the hydroboost hose; which makes me believe you pulled the 12v out of a 97 or newer? I'm not sure off the top of my head where that third one runs, since I don't have my hydroboost anymore...
