Carter fuel pumps
I'll have to check at the dealer in Canada to see if they have the heaters since we have Canadian warehouses that supply the dealers here. You might contact Mancini Racing in Detroit, www.manciniracing.com ? I think might be their website. From what I heard Chrysler is emptying some warehouses and Mancini had a bunch of that stuff for sale as they always have in the past for Chrysler.
They have this pump on their site:http://ep.yimg.com/ca/I/chucker54_2084_9531548
CARTER - 14-16 psi 100 gph
Get the fuel flow you need.
These universal rotary vane electric fuel pumps from Carter operate using leaded and unleaded gasoline, gasohol, and fuel boosters. They have an internal pressure regulating valve, and feature free-flow fuel delivery. These pumps have no points to burn out, and no shaft seals to leak or deteriorate. Easy to install, these universal fuel pumps come with a complete installation package and instructions.
$122.95
CARP4601HP
Edited by Racer Dan
  • Replies 1
  • Views 1.9k
Popular Days
$122.95
CARP4601HP
that pump is designed for gasoline not diesel. big difference in viscosity especially when the temps drop below freezing.
