- Replies 2
- Views 2.1k
98whitelightnin 1 post
diesel4life 1 post
For those of you running a 285/75/17 (or larger) tire, what do you do for a spare? Im about to pull the trigger on a set but I need to be able to carry a spare. There is only a hair over 33' between the frame rails, not quite enough. I'm thinking I may scab in a few pieces of angle iron the same depth of the frame rail so that the spare rests flat against the frame and the angle, but that also means it will now be hanging down 3 to 4" lower. Just curious if you guys have come up with any other solutions.JR
