Fuel pressure guage question
- Replies 7
- Views 2.6k
Ilikeoldfords 2 posts
panzerq 2 posts
Texas CTD 1 post
FrioFreddy 1 post
Hey everyone, Ive got a 99 2500 24v cummins, nv4500 tranny, edge comp box, 125 injectors, and a fass 150 fuel system.
Ive got a few questions about my gauges, they are all autometer cobalts. the EGT and boost ones work fine. the fuel pressure one has not worked since I bought the truck. Ive been messing with it lately to see whats wrong, and heres what ive tried to do.
When I first turn the key on, the gauge goes a little below the zero mark and dose the calibration.
I unplugged the harness from the sender,(the sender is ~2 months old and has a snubber before it), when I unplugged it the gauge slowly pegged its self out. I think I read that it means its grounding out somewhere?
Sender is plugged in on the outlet on the fass pump
I tried grounding the body of the send to the frame using a jumper cable but it didnt work.
Also the harness with the 3 wires was cut and extended so it could reach up to the gauges, all of the spots where it was cut are tapped up and no wires are showing.
Any ideas on what I should check next?
Thanks!
Edited by panzerq
