Air Dog fuel filter Supplier's
  • Replies 10
  • Views 3.3k
Donaldson p551315
Baldwin bd1275
Those are the best filters you can put on there
But lol where are you getting them from?
I cant remember. My charger on my laptop is broke and it has the link. Just do some searches for one filter and see if they have the other. Than compare the final price with shipping
Heck how often do you need to change the water seperator?  I havent changed it in a year and half.  but I drain it tho about every couple months.... :shrug:
whew Im ok then.... I do only about 10,000 a year anyway and usually when i change the filter I change that out as well since im at it.  :thumb1:
P550550 Fuel Filter Water Separators Product Attributes Outer Diameter:  3.11 Inches (79 MM) Thread Size:  3/4-16 Length:  5.59 Inches (142 MM) Gasket OD:  2.76 Inches (70 MM) Gasket ID:  2.48 Inches (63 MM) Efficiency 95%:  20 Micron Efficiency Test Std:  SAE J1985/J1488 Emulsified H2O Efficiency:  90.00 Percent Application Note:  Not for Marine Applications Primary Application:  CUMMINS ENGINES Price Type:  F   Packaged Dimensions Gross Weight in Pounds:    0.9 Country of Origin:    US (United States)   Other Item Information NMFC - USA:    069100-06 HTS - USA:    8421.23.0000 Division:    Engine and Vehicle
Direct from the donaldson website
