Fuel pressure on 3rd gen?
What pressure should I see on the inlet of the VP44 Fuel pump? Also I just replaced my fuel module in the tank and noticed there's a push pump on the module? So u s there 2 pumps before the filter housing?
  • Replies 3
  • Views 2.3k
Welcome to the forum! First off, I think you might want the 24valve forum. The 3rd gen dodge cummins trucks dont have a VP44, but rather a CP3 injection pump. They are common rail (CR) injected engines vs the old mechanical style individual cylinder injection like the VP44 and P-pumped 1st gen cummins motors.
Wasn't there a cross over year where they had 3rd gen body and still 24 valve engine? Like 2002 or 3? Critical to know common rail or not.
If it's a VP 44, 20 psi at idle.
One good pump should be enough. I'm going to go with a Bean Diesel sump and ditch the in tank suction draw all together. Sounds like someone added a new pump without removing the tank pump. Seems like 2 pumps is too complicated.
Edited by joecool911
The 2002 was all VP44 and in 03 there were all CR trucks. If you have a VP it's a 2nd Gen.
