Wires and Connectors
While removing my inner front fender cover I found two wire connectors [male and female] with many fine wires. they were attached to the lower rear of the drivers side wheel well and just inside of the outer fender and exposed when removing the inner fender cover. It just does not look like any electrical engineer would design a wire harness to just hang like this and not secured to anything for protection. Have any members found the same wiring on your Dodge/ Cummins. 1998.5, vp44 4x4 5 speed.
  • Replies 2
  • Views 1.6k
Some pictures would help us figure out if they are supposed to be there or not, just to be sure. That would be the best way to know.
